joancab
Advisor
Advisor
TEMAC free of charge hard license
I'm interested in using the 2.5G Ethernet subsystem IP core, that is licensed because of the TEMAC inside.
Apparently, there is a free of charge license for the hard TEMAC:
When there, only evaluation licenses show up:
sgeorgi_sen
Hi @joancab
you can not use something you dont have. It is as simple as that.
Virtex 5 and Virtex 6 had been equipped with a dedicated hardwired TEMAC. In your case there is no such unit.
Your only option is the soft TEMAC with license.
Sebastian
joancab
Advisor
Advisor
No feedback?
dpaul24
@joancab ,
As far as I know the TEMAC (10/100/1000 Mbps) IP core simulation license is free but the hard license is always an evaluation license.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
sgeorgi_sen
When using a FPGA with hardwired TEMAC you do not need a license.
See
https://forums.xilinx.com/t5/Design-Entry/DIFFERENCES-between-SOFT-HARD-TEMAC/td-p/158680
for futher details. Google helps.
Sebastian
joancab
Advisor
Advisor
@dpaul24
Not sure if we have the same core in mind, I'm targetting 2.5G
sgeorgi_sen
Hi  @joancab ,
can you tell us what FPGA you use?
Sebastian
joancab
Advisor
Advisor
Zynq us+, XCZU4EV
sgeorgi_sen
Hi @joancab ,
there is no hard TEMAC inside any Zynq's PL. So you will need a license to generate a valid bitstream.
Sebastian
joancab
Advisor
Advisor
@sgeorgi_sen
I want to use this:
https://www.xilinx.com/products/intellectual-property/axi_ethernet.html
If I click on the Order button, it takes me here:
https://www.xilinx.com/products/intellectual-property/temac-order.html
where it says:
 Further below in the same page there is this link:
And clicking on it takes me to the license search where such a free-of-charge license doesn't show up as per the screenshot in the first post.
Hopefully now we talk about the same thing.
sgeorgi_sen
Hi @joancab
Sebastian
joancab
Advisor
Advisor
certainly, how could I disagree?
so I assume where it says Zynq ultrascale+ MPSoC is supported, is it limited to the soft license?
Also, in the license search I'm not filtering for Zynq devices, so where is the hard license?
It looks to me something is missing
sgeorgi_sen
Hi @joancab
Virtex 5 and 6 are only supported in ISE, not in Vivado. Perhaps this is some leftover in the documentation of this core.
When I am informed correctly, there is no Vivado supported device with hard TEMAC.
Sebastian
