vhdlveri123
Two Aurora IP cores
I have a doubt regarding two Aurora IP core. In order to create a link between two FPGA boards through Aurora , do i need two Aurora IP?
Thank you.
rkhatri
Hi @vhdlveri123 ,
If you are using same bit file then you should use same clock source.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
kdeshwal
Hi @vhdlveri123 ,
Not necessarily, you can use 1 aurora IP in duplex mode.
But of course make sure that both the FPGA boards are identical.
To understand it more clearly, take reference from XAPP1228 (specially from page=20)
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
vhdlveri123
Hi ,
Thanks for the reply.
So use one Aurora core and download the bitfile in one FPGA?
kdeshwal
If boards are identical then you can also program another board with same bit-file.
vhdlveri123
If both are same boards, then should I use same clock sources for both the boards?
rkhatri
Hi @vhdlveri123 ,
Rahul Khatri
