arotenst
Vivado 2018.3 Clocking Wizard Reset polarity change
I have Vivado 2018.3 and using Block Design. I connected reset input of the Clocking Wizard block to pcie_perstn port with active low polarity. I cannot change the reset polarity in Clocking Wizard block. It is still active high with no option to change. What is the work around? I do not want to generate another reset signal.
Thank you.
arotenst
Found it in the Output Clocks hidden in the bottom.
arotenst
