Apart from the externally fed primary clocks' create_clock what other constraints go into the ooc xdc file ?
eg - virtual clock create_clock ? set_clock_groups_asynchronous b/w primary clocks ?
Also, after splitting the xdc, I cannot use the same project configuration, as I see I can have only one target xdc, choosing any one of the two does not allow to run timing/cdc check on the project. How can I have a single configuration that works as a project as well as to package as an IP ?
Thanks and best regards
Bhawandeep Singh
