_underscore_
XADC in ZYNQ
Hello everyone,
I am currently using an XADC in unipolar mode, and I am trying to save in I/O. So I was wondering if the XADC can still work if its auxiliary _N inputs are not connected (or all connected to the same ground pin). Any information or suggestion is welcome.
Thank you.
@_underscore_
Welcome to the Forum!
On UltraScale devices (where the XADC is called SYSMON), it is possible to connect an analog input only to the P-side (VAUXP) and use COMMON-N to have all the N-sides connected to a common ground.  -see UG580(v1.10) pages 32-34 for details. When using VAUX connections on UltraScale, you must be careful about connections for unused VCCO pins as described by tenzinc in the following post.
https://forums.xilinx.com/t5/Versal-and-UltraScale/Ultrascale-XADC-non-linearity/m-p/1131049
On 7-Series devices (where the XADC is called the XADC), “all analog input channels are differential and require two package balls” as stated on page 17 of UG480(v1.10.1).  For 7-Series devices, you will find the XADC Wizard described by document, PG091, to be a convenient tool for setting up and using the XADC in your design.
Cheers,
Mark
@_underscore_
Cheers,
Mark
