ehsan.tavakoli
XAPP1115, XAPP116, XAPP1120, XAPP1139
How can we access the following documents?
XAPP1115
XAPP1116
XAPP1120
XAPP1139
They have been mention in the attached document while the link to the wireless website is not found.
florentw
Hi @ehsan.tavakoli
If you cannot find them on Xilinx.com, this is very likely that this documents are deprecated thus were removed from the web.
So I do not think you will be able to access them
Florent
