XDMA bypass addressing
Is there a restriction that the addressing on the XDMA bypass channel needs to be 32byte(8 dword aligned)? I am running simulations and when it is 32byte aligned all my writes go through and when I make my address 8byte aligned then my write gets stuck . Thanks.
Hi @vinit.apte,
Please check the "Descriptors" section in the PG195:
Best regards,
Abdallah
Hi @vinit.apte,
Best regards,
Abdallah
Thanks a lot Abdallah. Appreciate it
You are welcome @vinit.apte!
Best regards,
Abdallah
