takaka
ZCU208 Manual - Just confirmation of the Latest version
Sorry for the fundamental question.
But I just want to confirm the latest version manual of pin numbers of ZCU208 board.
I found two manuals on Xilinx webpage:
#1 : ZCU208 Evaluation Board User Guide, UG1410(v1.0) July 8, 2020.
#2 : HW-Z1-ZCU208, Friday, November 22, 2019, RevA02 (xtp653?).
There are pin numbers of the board, but some numbers are different.
Probably #1 is newer than #2, then where is the latest version of #2 ?
I also want to confirm whether or not #1 is the latest version.
Best Regards,
florentw
HI @takaka
I believe this is what you are looking for:
 XTP653 - ZCU208 Schematics (v1.0)
Florent
florentw
HI @takaka
The following page should have the latest version of all the documents related to the ZCU208:
https://www.xilinx.com/products/boards-and-kits/zcu208.html#documentation
Florent
takaka
Dear @florentw ,
Thank you for your quick reply!
Then, is the newer version of the file below not yet released?
Please tell me the folder name if it exists.
Best,
florentw
HI @takaka
Florent
