avaarahoon
no packets on m000_data_axis port of ORAN Radio IF
We are working on the wireless-xorif design. We debugged s0_eth_axis and m000_data_axis ports. Hardware debug shows that there are no packets on m000_data_axis even if ORAN C and U plane packets received on time. The advance time matches with DU. What are the possible reasons of this problem?
The statistics of front-haul interface is something like that:
root@zcu102_om5_exs:~# xorif-app -i -c "get fhi_stats 0"
init   => status = 0
get fhi_stats 0 => status = 0
total_rx_good_pkt_cnt = 456955
total_rx_bad_pkt_cnt = 0
total_rx_bad_fcs_cnt = 0
total_rx_bit_rate = 652387904
oran_rx_bit_rate = 643084800
oran_rx_total = 456241
oran_rx_on_time = 5629
oran_rx_early = 221717
oran_rx_late = 227360
oran_rx_total_c = 15733
oran_rx_on_time_c = 2493
oran_rx_early_c = 5347
oran_rx_late_c = 7840
oran_rx_corrupt = 0
oran_rx_error_drop = 0
oran_tx_total = 0
oran_tx_total_c = 0
offset_earliest_u_pkt = 70
offset_earliest_c_pkt = 70
xud
@avaarahoon
From the packets counter, it seems that reception window is too small, as not all the packets arrive on time, some are early and some are late.
xud
@avaarahoon
I just checked your IP GUI settings. the CONFIG.Xran_Max_Dl_Ctrl_1kWords is not enough. Buffer number is calculated by (Section per CC) (CC number) (Symbol number)/1024, and round up to a integer
Based on your GUI setting 275*1*29/1024 = 7.78,so you need to set it to 8 in IP GUI, but you set it to 5, so buffer is not enough.
For more details, please refer to page 24-29 (Memory Structure) of PG370, and check if other buffer values are large enough.
xud
@avaarahoon
Can you provide all the xorif-app commands after you boot the board?
What O-DU do you use?
xud
@avaarahoon
When I open you pcap, I notice the length of U-Plane data are not the same.
I will check if we have validated this or not.
xud
@avaarahoon
I just realized the PRB numbers are different, so pcap should be okay.
From the get fhi_stats 0 result, following offset values are way too big. It seems the packets are not synced properly.
You probably need to re-evaluate the packet arriving time.
Can you refer to line 221 and onwards of https://github.com/Xilinx/wireless-xorif/blob/master/scripts/xil_vivado_build.tcl?  and add debug signals to ILA
Please observe how header are missed in m0_packet_in_window, we can get more hints from that.
xud
@avaarahoon
I had a quick look at the file, the app_head_valid looks a bit strange.
I would expect it asserts once for every symbol
Also can you export ILA data, so I can import it at my end, and see ILA waveform?
