vivado displays an error when trying to set output width of a slice ipcore
Trying to use slice ipcore in block design but I get this warning with the following two tcl commands
set xlslice_6 [ create_bd_cell -type ip -vlnv xilinx.com:ip:xlslice:1.0 xlslice_6 ] xlslice_6
set_property -dict [ list CONFIG.DIN_FROM {43} CONFIG.DIN_TO {22} CONFIG.DIN_WIDTH {44} CONFIG.DOUT_WIDTH {22}] $xlslice_6
WARNING: [IP_Flow 19-3374] An attempt to modify the value of disabled parameter 'DOUT_WIDTH' from '1' to '22' has been ignored for IP 'xlslice_6'
I am not sure why. Thanks for any help
Amish
Hi @amishmks ,
From the information which you've provided, syntax of first command is incorrect. It should be 'set <variable_name> <variable_value>'. If I just remove last  xlslice_6 from first command, I can run both commands correctly without any issue. So it would be better if you attach your complete script for further debugging.
Ashish
There is no script that I run these commands in. That was a copy and paste error which included the return from the first line. Here is a picture
Hi @amishmks ,
Can you share output script of below command -
write_bd_tcl -no_ip_version recreate_bd.tcl
Ashish
