vivado2018.3 how to save the fifo depth ?
Why can't modify the fifo depth ?
When I changed the fifo depth from 64 to 128, i can't save this modify, the OK can't type
Is the FIFO IP locked? Can you generate a new FIFO IP in the project?
Please Kudo or Accept as a solution, If this Post helped you.
yes,locked。i creat a new IP
