xadc
Hello..
i am faceing issues with interfacing xadc with the zynq device . i am useing zynq xcz0730sbg485 som module in this som module i make a connection too the Vp and Vn pin nad DXp and DXn pins with two sensors i need to read the data from the xadc . how to implement the xadc ip for this purpose?
please provide any reference design for this to solve.
i have quation that i make a external connection to the xadc ip with Vp and Vn input and how to read the DXp and DXn data ?
Re: xadc
Hi @thokalanaresh99
UG480 - XADC User Guide is a great place to start. (designs)
XAPP1183 describes how the XADC acquires analog data using its dedicated Vp/Vn analog input (designs)
Cheers
Re: xadc
Dxp/n is a temp diode. It's not connected to the XADC...
Re: xadc
we can't use the Dxp/n pins as external auxilary anlog input for the XADC ip
Re: xadc
Hi @thokalanaresh99
When not used to access the thermal diodes, they should be tied to GND.
Cheers
Re: xadc
Dxp and Dxn pins can be grounded okk.
How to read the data from Vp and Vn throgh AXi-lite interface . for the how to make the dtsi file and how to get data in the kernal.
i am litle bit conficuing with the Vp and Vn use i don't know how to use this two pins as external .
 i take the XADC-wizard ip and i take Vp and Vn as external and  i assign the pin location for the Vp and Vn and i create the HDF know how to get the data in the kernal while booting the device.
