ML Suite on AWS
I'm trying to run 'classify' example from ml-suite.
As I'm using ml-suite AMI, and I'm expecting all the required software/packages are already installed. But I could not find them (Anaconda, ml-suite repo). I have installed them as per instructions in github.
Ended with some warnings and errors:
AwsXcl Cannot open userPF: /dev/dri/renderD0
cxlOpen Handle check failed
I guess there is some issue with the driver. To fix it, I looked for setup.sh of SDx, which I did not find.
Is SDx not installed already on this AMI?
Any hint about this issue will be helpful to me.
Thanks and Regards,
Ravi
Re: ML Suite on AWS
Hi AWS is currently being updated to supported the latest ML Suite 1.2. This upgrade should be complete in a couple weeks. If you need the to utilize AWS sooner, please send me a private message and I can see how we can help. Thanks, Kamran
/k
