When ML-suite v 1.2 is realeased ?
I'm trying on branch v1.2 on ml-suite ( https://github.com/Xilinx/ml-suite/tree/v1.2 )
It also has an instruction to compile tensorflow https://github.com/Xilinx/ml-suite/blob/v1.2/notebooks/image_classification_tensorflow.ipynb
But when I run that example, I got error as below. And I guess that v1.2 is not released.
So I would like to know when ml-suite will be released v1.2 ?
Thank you very much !
Re: When ML-suite v 1.2 is realeased ?
Have you downloaded and installed the models? Instructions can be found here:
https://github.com/Xilinx/ml-suite/tree/v1.2#getting-started
Kamran
/k
Thank you for your quick reply.
I also downloaded the model. As you can see like below:
And I got this source from master branch ( it was merged from v1.2 to master three days ago ).
So could you please advise me on this ?
Long.
Hi, You also need to download the models from here:
https://www.xilinx.com/member/forms/download/ml-suite-eula-xef.html?filename=models.zip
Please download and unzip the models and copy them to the /ml-suite dir.
/k
Hi @kamrank,
I also downloaded and extracted the newest models from xilinx into /ml-suite directory.
But I still got the same issues.
And I also tried on other machine ( ubuntu16.4 ) and it got the same issues.
Do you have any advice on this ?
Long.
