error while loading shared libraries: libxilinxopencl.so: cannot open shared object file: No such file or directory
VCU1525
When I run the test case /opt/dsa/xilinx_vcu1525_dynamic_5_1/xbinst/test/verify.exe
error info as follow:
lab1@lab1-pc:/opt/dsa/xilinx_vcu1525_dynamic_5_1/xbinst/test$ ./verify.exe verify.xclbin
./verify.exe: error while loading shared libraries: libxilinxopencl.so: cannot open shared object file: No such file or directory
how can I solve it? thank u
Participant l502418608
回复: error while loading shared libraries: libxilinxopencl.so: cannot open shared object file: No such file or directory
Did you solve it?If you do,Can you tell me how to solve it?
What version of SDAccel are you using? Did you set up the environment variable correctly?
I use SDAccel2018.2,My board is KCU1500,And My errors is that:
KCU1500 ./verify.exe verify.xclbin error(core dumped)
I installed the KCU1500, Then I want tho run the helloWorld,But When I run the  ./verify.exe verify.xclbin,errors occured,like this,what should I do?Screenshot from 2019-09-14 11-14-38.png
I need your help!!!
Hi @l502418608 ,
Can you check with SDAccel - 2018.2 XDF edition.
I have tried sdaccel examples with this, for me it worked.
If you find this information useful please add kudo and accept this as solution.
