Serial connection not working on Xilinx Zynq UltraScale+ MPSoC ZCU102 Evaluation Kit
We got recently the Xilinx Zynq UltraScale+ MPSoC ZCU102 Evaluation Kit and I have been unable to get the serial connection working.
Can anybody please shed some light (steps) on to how to connect via serial to this board?
Thank you!
Victor.
Re: Serial connection not working on Xilinx Zynq UltraScale+ MPSoC ZCU102 Evaluation Kit
Hey @inviktor,
Maybe this wiki entry helps?
All the best,
Herbert
The ZCU102 UART-USB connector is tied to a Silicon Lab QUAD chip:
      4 UARTs can go through the USB
I am using UART PS device #0 (same one as on the supplied MMC) and it is on the 2nd bridge of the Silicon Lab.
In Teraterm / Windows the 4 bridges are shown in the "port" pull-down menu.
Hoping this helps,
Just checked it....
Bad memory, it's the 3rd one
@ericv I always go to Windows/Control Panel/System/Device Manager
They are always in order there
* Henrique Bucher, Baremetal Labs, Extreme Financial Engineering: btlabs.us
@hbucher
Yes, I should have done gone through all the "necessful"   :-)
Hi Everyone,
Thanks a lot for all the responses. Unfortunately, I am still blocked. I cannot get any output from the board.
I tried all the HDMI and Display ports, and I get nothing. I tried all mini-USB, and nothing. I see the LED DS47 (sysctrl) flashing with green light, on and off. Does anybody know of this is expected?
Also, my host machine is a Ubuntu 14.04, so I downloaded the driver for it, from here, from the twiki hpoetzl suggested, and I get a lot of "no such file or directory" errors for header files.
I don't know what else to do.
Thanks a lot!
This is one error I get when I try to compile the driver:
{local@serialc:52} make cp210x
cc cp210x.c -o cp210x
cp210x.c:18:24: fatal error: linux/slab.h: No such file or directory
#include <linux/slab.h>
compilation terminated.
make: *** [cp210x] Error 1
Another problem I have with the board is the lack of documentation on how to properly set the switches.  I followed the BIST setup to double-check the board is configured properly, but now every time I reset the board it tries to do the test again, which need physical pushing of bottoms, which is not desirable.
Does anybody know what is the default position for the pins of all the switches on this board? The documentation Board User Guide could not be more complicated to read, and I see no clear explanation of this.
Thanks!
Ok, I found the Switch defaults now, although it still doesn't work.
